How to solve function palette license error?
What should I do when the function palette I want to use have license error?
Or can it replace by the other functions palette?
The palette is event structure....
Message 1 of 8
(5,011 Views)
Can somebody help me please......
Message 2 of 8
(4,962 Views)
What version of labview are you using, have you run the liscence manager and applied the correct liscence for your product?  If you are running labview base the events are not part of the environment (I think, I use the professional developers suite).
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 3 of 8
(4,956 Views)
I'm using LabVIEW 8.5.1, and I have entered all the activation keys.... yes, i'm using the base development version, but my seniors still can use that palette......
Message 4 of 8
(4,953 Views)
You simply do not have access to the event structure with the base license. Perhaps the seniors are usung the student edition which I believe does include the event structure.
Message 5 of 8
(4,938 Views)
Then what should I do for access the license?
@Dennis Knutson wrote:
You simply do not have access to the event structure with the base license. Perhaps the seniors are using the student edition which I believe does include the event structure.
Message 6 of 8
(4,910 Views)
I'm not sure I understand the confusion. The only way to get access to the event structure is to have a license for LabVIEW Full or above.
Message 7 of 8
(4,891 Views)
okay... thanks for all the informations...
Message 8 of 8
(4,856 Views)
