ring items from table col header
Can anyone please tell me how to set the items of the text ring "Column to sort" in the array "Sort parameters" programatically according to array "Items 4 "Column to sort". That is a) the column header from the table and b) a standard text in position 0.
I now entered the items at design time but the column headers can change during program execution, so I need the items in the text ring to change accordingly.
Attached my test VI in LV8.6
Thanks for any suggestion/solution 🙂
(2,726 Views)
Ok, problem solved 🙂
I was first starting with the reference of the array instead of that of the ring text inside the cluster.
(2,715 Views)
