How to solve this problem? (About Labview ver.2017 NI-Daq MX Driver)
Hi, I'm trying to run some programs about rotating Magnetic field, and testing now.
The problem is, I can't use those programs because of NI-DAQmx Driver (ver.2017)
I have installed all NI-DAQmx Driver at the VI Package manager but I can't solve it...
If you guys know the solution of this problem, please write a comment below....
(1,137 Views)
Hi Jmap, those are not DAQmx drivers on VIPM, those are just templates that use the drivers (I believe).
If you want DAQmx (as well as other drivers) you need to install "NI Device Drivers". You can download from the link below, or use NI Package Manager to install.
https://www.ni.com/en-us/support/downloads/drivers/download.ni-device-drivers.html#327641
(1,127 Views)
