How to split the string from character position.
HI ALL,
I need to split the string like this.
example:
String = "HelloWorld"
mid("HelloWorld", 2, 5);
it should print   "ello"
menas mid is functiuon it will split "HelloWorld" from 2nd character to 5th character and prints "ello".
This one how to do in labview.
Regards
Punith
Message 1 of 17
(8,263 Views)
The "string subset" function. It takes a length rather than an endpoint but will do what you want.
Message 2 of 17
(8,255 Views)
I would go for two consecutive calls of string subset.
Remember Cunningham's Law
Message 3 of 17
(8,253 Views)
String Subset is the function you are looking for.
Message 4 of 17
(8,243 Views)
Peter, why do it twice? You can write both the start and length inputs, it's not either-or.
Message 5 of 17
(8,238 Views)
Smiley Very Happy
I guess this qualifies as an entry for Rube Goldberg code....
Dammit, any other day I would have noticed.
Message 6 of 17
(8,228 Views)
Also note that the String Subset function uses an offset input, setting this input to 2 will make the 3rd character of the string the first one of the subset. If you want to output "ello" you need to set the offset to 1 (2-1) and the lenght input to 4 (5-(2-1)).
Ben64
Message 7 of 17
(8,216 Views)
But if i want to split same string from 5th postion to two character , it is not working.
ex : mid("HelloWorld", 5,2);
it should print "oW".
How to do this.
Regards
Punith
Message 8 of 17
(8,201 Views)
As Ben64 noted, the start input is an index (starts at 0 for the first character) so you need the inputs to be 4 and 2. You would have found this out faster by trying it out than by posting on the forum.
Message 9 of 17
(8,187 Views)
I understand that in labview  char position of string starts from oth postition .
But my proble is if  i want interchange 5 and 2 its not working.
ex: mid("HelloWorld",5,2);
it should print "Wo" but it not working.
Regards
Punith
Message 10 of 17
(8,148 Views)
