String to Binary
Hello, im new in labview and i have a problem.
I have an Input String and i need a binary exit.
For example: if i write at the input HELLO WORD the result is: 01001000010001010100110001001100010011110010000001010111010011110101001001000100
And viceversa, if i have in the input 01001000010001010100110001001100010011110010000001010111010011110101001001000100 the result must be: HELLO WORD
Please let me know if any more info is needed, thank you for the help!
(4,691 Views)
Have you tried searching the forums?
This question has been asked hundreds of times before.  A search with browsing through the first page or two of results should give you a clue as to how to do it.
(4,682 Views)
It looks like a basic homework assignment. 🙂
Try to take a look on the function palette and check how the "type cast" and "number to binary array" functions work.
CsabaF
(4,641 Views)
The String To Byte Array and then a FOR loop with Format String would be a lot easier.
(4,613 Views)
 Ahh, great idea! I have just tried it during my coffee break and that method simplifies the conversion quite much  - I should spend a bit more time playing around with the string formatting vis, those are very efficient in some cases.
CsabaF
(4,604 Views)
