How to start acquisition on rising edge without using external source
I use NI 6368 DAQ card. I would like to start digital acquisition on the first rising edge ( first 1) without using an external source. Sounds like I can't use Onboard Clock since it is in use for digital acquisitiion. Could you please let me know how can I do it? Do I need software trigger?
Message 1 of 15
(3,870 Views)
Any help really appreciated
Message 2 of 15
(3,844 Views)
Triggering is separate from an external clock or the onboard clock so your question does not make much sense. Your board supports both analog and digital triggering.
Message 3 of 15
(3,834 Views)
Yes it supports both but how can I set it. For trigger I need a source. How should I set the source to start acquisition on first detected transition on that digital line?
Message 4 of 15
(3,817 Views)
You may select the any Analog input channel from 0 to 15, as your card supports that.
So if the rising edge signal needs to be connected to analog input and select the trigger source as that channel
http://zone.ni.com/reference/en-XX/help/370469AB-01/lvdaqmx/mxtrigger/
AB
Kudos are Accepted
Message 5 of 15
(3,794 Views)
Just connect a physical wire from your first digital input line (e.g. P0.0) to one of the PFI lines and use that as the trigger.  When your signal goes high, it starts acquiring.
http://www.medicollector.com
Message 6 of 15
(3,778 Views)
Another option would be to have it just continually acquiring and do a "software trigger" where you just start saving / processing the data once it goes above a certain level.
Message 7 of 15
(3,768 Views)
Do you ahev any suggestion or an example on how to do software trigger on digital signals
Message 8 of 15
(3,761 Views)
Has anyone any suggestion on how to use software trigger for a digital line. I could find this example but it is for analog
https://decibel.ni.com/content/docs/DOC-11764
Message 9 of 15
(3,744 Views)
any help is really appreciated. I can't use any PFI line or analof lines since they are all in use so I can't use an external hardware trigger. I would like to start acquisition as soon as seeing the first rising edge on my digital line.
Message 10 of 15
(3,705 Views)
