How to start acquisition on rising edge without using external source
In another post of yours, you asked about digital pattern detection and were given an answer. Why are you still asking?
Message 11 of 15
(610 Views)
Wait a sec. Are you saying that basically ALL the DI, PFI and AI pins are occupied?
If so then your best solution is to just continuously record data into a buffer and then use software to scan through your trigger signal and throw away all the data that comes before the rising edge that will work fine. It just requires a bit if programming.
http://www.medicollector.com
Message 12 of 15
(596 Views)
Yes, all the lines are occupied and I can't use any signal as external trigger. Do you aheva n example of how to buffer data and then through away the part before trigger?
Message 13 of 15
(585 Views)
Message 14 of 15
(584 Views)
