Showing results forย
Search instead forย
Did you mean:ย
How to stop a VI in a subpanel (the best way)
I'm trying to figure out the best way to stop a VI, in a subpanel, which normally uses "Window: close" for stopping.
I have tried the following methods (just for testing):
This works, but its not a good way to stop a VI.
This also works, but then a "Stop" button must be added to the "TestVI" as an alternativ to the "Window: close" event.
This does not work, but I wish it did (as it would trigger the "Window: close" event)๐Ÿ˜…
So, what would be the best approach, in this case, for stopping the VI (in a subpanel)? ๐Ÿค”
(PS: If the last alternativ with "Close window" can work, if wired differently, please let me know๐Ÿ˜)
________________________________________________
"Science is about knowing, while engineering is about doing"
(2,048 Views)
Accepted by topic author S.Stock
I recommend you explore the option of using User Events. I usually rely on those when I asynchronous VIs I need to stop from a caller GVI, and still want to be able to test them separately.
This is how the caller looks like:
This is what the called looks like:
Disclaimer: I prefer using the function Start Asynchronous Call and passing the user even through the connector pane. However, this functionality has a bug up to version 5.0, hence my approach of using a Set Control Value and Run VI functions combination.
All the best!
(1,970 Views)
