How to stop a while loop in LabVIEW from a C program
How to stop  a while loop in LabVIEW from a C code
(3,142 Views)
hi
I think by creating dll you can stop the while loop from your C program.For that you just create dll (Dynamic Link Library) for the VI which has that while loop.
     Anyway can u please explain ur requirement clearly.
(3,136 Views)
While you can use a DLL to run LabVIEW code from C, you would still need a mechanism to stop the loop. So, the question really becomes, how is the loop stopped in the first place?
(3,117 Views)
