How to stop two or more while loops running at different speed at the same time?
Dear Tim,
Thank you!
However, there was a problem with this method.
When the STOP is initially a false value, I can still run the program.
so I add a logical OR and a STOP to prevent the program from running; however, this doesn't work; the program still runs although it stops after 8000ms.
Should I add a case structure on the event structure?
Thanks!
Message 11 of 14
(765 Views)
You do understand that if you succeed in what you are trying to do, your processing loop will not complete its processing, right?
Bill
CLD
(Mid-Level minion.)
Message 12 of 14
(755 Views)
Whatever you did makes absolutely no sense.
Change the mechanical action back to "latch when released", get rid of all the green local variables and follow more closely the example given. All you needs is a TRUE constant in the stop event.
Message 13 of 14
(751 Views)
Thank you so much!
Message 14 of 14
(705 Views)
