VI able to run while error exists
I have an error because a global variable is not defined, but the VI is still able to run.
(2,895 Views)
Interesting, is there anything funny about this VI? Did you upgrade it from a much older version of LabVIEW?
(2,851 Views)
If you hold Ctrl and press the run arrow, does the VI become broken?
(2,836 Views)
Interesting, but that is a local and not a global (notice the house and not the globe).  Doesn't explain the behavior.
(2,828 Views)
Attach the VI that is doing this so others can try it out!
(2,815 Views)
Right, local, sorry.
(2,804 Views)
Unfortunately, when I tried to select an object for the local variable to link to, LV crashed.
Next time when I opened the VI it showed the error correctly.
It was a VI developed few days ago, think I saved it initially with the error, I don't remember, LV 2016, so I think it's not very important.
(2,800 Views)
