How to subtract ith position of one array from the ith position of another
Hi, everyone,
In my program, I subract one array from another. It should be like X(i) - Y(i)
Can someone explain to me how I can make sure that I'm subracting ith value of array 2 from the ith value of array one?  Not , for example, X(i)- Y(i+1)?
Thank you
(3,330 Views)
Accepted by topic author nwg
In LabVIEW the polymorphism of the substrat function let's you directly substract one array from the other. If I understand you correctly, this will be what you want.
Also seems that you are new to the concepts: Take a look at the auto-indexing posibillities of for loops.
Felix
(3,321 Views)
Hopefully, you are not doing anything more complicated than this:
This does X(i) - Y(i).
Message Edited by Dennis Knutson on 12-21-2009 10:59 AM
(3,320 Views)
Thanks everyone.
I am using subtract function, but I wasn't sure if it did X(i)-Y(i).
(3,308 Views)
