display vi reference number as integer value
hi all,
   I'm trying to create a "Watch" vi to use for debugging a problem i'm having with Vi reference numbers.   When i create a probe for a refnum on the block diagram, it displays an integer value that you can understand.  When i try to create an indicator to display the same refnum on the Front panel it shows up as the square checkered refnum icon.
  Is there a menu selection i'm missing to make it display like the probe and not as an icon?
thanks
(6,317 Views)
Accepted by topic author joshuatree
Use the Type Cast primitive to convert the reference to a U32.
___________________
Try to take over the world!
(6,307 Views)
thanks tst.     Simple!
i won't belittle myself and tell you some of the other dumb things i tried...
(6,286 Views)
