How to switch booleans whithin a loop to 0 when stop is hit
I am trying to write a program than can send digital signal to an external oscilloscope. I am using NI-USB-6008. The program runs but when I hit "STOP" button (while the On/Off signal's boolean switch is on) the oscilloscope still shows an ON signal.
The problem: How to switch the boolean to Off immediately when I press STOP?
I tried using "Clear Task" and "joining the STOP button with the boolean switch but nothing change. Please find attached my program.
Message 1 of 11
(3,692 Views)
ORing the stop button will obviously not work since you would be sending a True from the button.
Simply do another DAQmx Write before the clear task.
Message 2 of 11
(3,690 Views)
You could do something as follows (note the invert circles)
Message 3 of 11
(3,678 Views)
Accepted by kthouz
 since you are looking at error status in the loop conditional logic I would recommend putting a second write outside the loop to garantee the write happens when exiting on error. Additionally, add an error handler after the clear task .
Message 4 of 11
(3,669 Views)
Depending on what the error was, the last write might fail inside or outside the loop, so there is no real difference to my suggestion.
You would also need to clear the error before the last write outside else it would not do much anyway..
Message 5 of 11
(3,661 Views)
@altenbach wrote:
Depending on what the error was, the last write might fail inside or outside the loop,   Exactly- and the most compelling reason to add an error handler
so there is no real difference to my suggestion.  Except the user is notified of the error and that the hardware may not be in the expected state Smiley WinkSmiley Surprised
You would also need to clear the error before the last write outside else it would not do much anyway..Pssst it was or more correctly the write outside was not passed the error out from the loop and a merge errors is used to pass on the error information
Message 6 of 11
(3,655 Views)
Fortunately, automatic error handling is enabled by default... so the clear task will bark anyway. 😄
Message 7 of 11
(3,651 Views)
Oh- I've dissabled error handling in my LabVIEW.ini so long ago that I forgot.  Didn't everyone?Smiley Very Happy
Message 8 of 11
(3,645 Views)
I don't really care to leave it enabled, because my code never produces any error anyway... :o:D
Message 9 of 11
(3,639 Views)
Thanks a lot. Actually, I am new to LabView, would you suggest me any book with enough tutorials and exercises that can help me?
Message 10 of 11
(3,629 Views)
