How to switch from labview 2018 32 bit to 64 bit
Anyone know how to change labview bitness from 32 to 64? Current bitness is 32 and I already install both bitness
(2,670 Views)
Accepted by PULSE.Wannabe
Save and close everything open in LabVIEW 32bit, then open it in LabVIEW 64bit (different program!).
(2,667 Views)
Also, you need to explicitly open correct LabVIEW, because double-clicking on a LabVIEW file will open the last LabVIEW application.  Even choosing "open with" and the correct LabVIEW will actually still open the last LabVIEW that was opened.
Bill
CLD
(Mid-Level minion.)
(2,652 Views)
