How to switch multiple relays using PCI 6601 DAQ card
What is the specification of the digital output value given from the PCI 6601 DAQ card?How to develop LAB VIEW code to switch a relay?Can anybody please explain?
(3,096 Views)
Hi hasi,
did you read the manual and the specs of the PCI6601? It says: "5V TTL/CMOS compatible"...
You shouldn't expect to much current from a simple DO pin - probably it's not enough to drive your relay!
(3,087 Views)
Thats Ok anyway and my problem is with the software.Is it possible to throw a continuous high value from a particular digital output pin and give that as input to energise the relay coil?Can u demonstrate with a sample code?
(3,078 Views)
There are example coming with LabVIEW?
Did you open the example finder?
(3,074 Views)
I hav attached the snap shot of the code .An error message "-200014" is being displayed. Can you pls help me out?
(3,071 Views)
Hav solved the issue yar.... I have put both the task input and the line input for create virtual channel.vi,that was the mistake in the code.
(3,063 Views)
