Labview Remote conection and acquire sound and image
Good afternoon for everyone,
What I want is the following:
1. º How do I record values from a graph in Excel by pressing a button (eg recording).
2. º How do I show my power picture and sound on my pc through the microphone and webcam laptop by pressing two buttons, for example sound "on" and picture "on" and do the "off" to both.
3. º How do I power fizar my IP, since I already did what was on this page and I can not communicate with any other PC.
http://redacacia.me/2010/10/15/internet-control-of-a-labview-vi-part-ii/
Please find attached the program.
Thank you and if I can help thanks a lot!
Best Regards,
FASP
Message 1 of 16
(3,720 Views)
I'm sorry, but from your description I have no idea what you are trying to do. Ok, I see that LV is doing something, and that you want to acquire sound and images, and that the web is apparently involved. But,
  1. How is Excel involved?
  2. What is the web interface doing?
  3. Where are the buttons you talk about pressing located?
  4. What are the sound and video sources?
  5. What version of LV are you using?
  6. What is the network you are using?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 16
(3,712 Views)
I Mike,
first of all I will try to explain what I want.
Forgetting what I sent:
1. º needed to know how to put the values of a sensor that appear on a chart in excel. This order should be given by a button. Could later refer to this file in excel.
Can you help me?
2. º needed to know how to acquire image webcam integrated into the laptop and the sound of the laptop, when I press a button on labview.
When I click on another button the picture and sound is turned off.
3. º I make a remoting application developed in labview from another PC elsewhere.
I used the Web Publishing Tool. The problem, I realized what it was I did not have a fixed IP. Can I do that?
Best regards and thanked lot for your help!
Message 3 of 16
(3,707 Views)
Please, help me.
Thanks for all
Message 4 of 16
(3,657 Views)
PLEASE HELP ME...
Regards
Message 5 of 16
(3,655 Views)
Hello fasp,
1) Do you want to copy/transfer data from Excel to LabVIEW or from LabVIEW to Excel?
2) This example should already get you started:
https://decibel.ni.com/content/docs/DOC-25670
It's not perfect, but it does show some of the concepts.
3) This question is not a 100% clear to me.
What is your native language?
PS: Posting two times (with only 5 minutes in between) will not make people help you faster. Especially if the post doesn't contribute to the problem description.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 6 of 16
(3,637 Views)
Hi ThiCop,
In the third question i need to commuicate with my aplication in labview from another PC in anywhere place. So to do that i need to fix my IP. Can u help me?
PS: Im portuguese. 🙂
Message 7 of 16
(3,626 Views)
For your information:
There is a Portugese forum you could use (if you prefer using your mother language):
http://forums.ni.com/t5/Discuss%C3%A3o-sobre-Produtos-NI/bd-p/9170
Concerning the fixed IP:
Are you using LabVIEW on both PC's?
Where are both pc's located?
What should each pc be doing?
Kind Regards,
Message 8 of 16
(3,619 Views)
There my responses:
Are you using LabVIEW on both PC's? No, only in one PC
R: Both Pc's are located in a division with a public network
R: My PC had the application and any person acceded to the application to be able to work on it.
Regards
Message 9 of 16
(3,609 Views)
There my responses:
Regards
Message 10 of 16
(3,608 Views)
