How to synchronize Analog generation with digital input
I use a DAQ 6713 to generate an analog ramp voltage at a variable frequency. I need to detect an external signal to calculate the time delay between that one and the analog ramp start.
By adjusting the analog ramp frequency I can control the time delay. The aim is to decrease that time to reach a zero time delay.
How can I do that with labview
Any assistance will be greatly appreciated
Thank you
R
(2,622 Views)
Renaud;
One thing you can do is to use the begining of the Analog Output operation to start a timer and use that external signal to stop the timer. There is one good application notes you can refer to and learn how to synchronize operations on DAQ board. The name of the App Note is "Advanced Synchronization Techniques for Data Acquisition", and can be found at our home page. You can use that external signal as the gate of your counting operation and having the source of that counter as being the internal board timebase. As you know the frequency of that timebase signal, you just multiply the number the counter will return after the counting operation stops by the frequency of the timebase signal, and you have the time delay.
Hope this helps.
Filipe
Na
tional Instruments
(2,622 Views)
