How to synchronize in one PXI chassis DAQ with SMU module
Hi All,
What I have:
PXI-1031 chassis, PXI-8187 controller, PXI-6122 DAQ card, PXI-6281 DAQ card (at once I am using only one of DAQ and I can use better for my job),  BNC-2110 and CHROMA PXI-52411 SMU card, operating under RT OS controlled through Ethernet by laptop with Win 7.
What I want:
I want to synchronously start measurements with one of DAQ (not important for me which) and SMU. After each trigger I want to measure few samples with DAQ and SMU. I have triggering events each 1 ms. Analog trigger enters system through DAQ connector board.
What I can do:
I can measure few samples with DAQ what was discussed here:
http://forums.ni.com/ni/board/message?board.id=250&thread.id=25264,
but now after each of external triggers comes I want to initiate SMU measurements. I can send software trigger to SMU or I can use TTL triggers of PXI to initiate SMU (SMU can be triggered from PXI TTL lines).
The problem is how to synchronize both measurements. How to be sure that DAQ and SMU measures data after the same ext trigger pulse?
Maciej
(3,103 Views)
Hello Maciej,
the link  I can measure few samples with DAQ what was discussed here: http://forums.ni.com/ni/board/message?board.id=250&thread.id=25264, is broken.
Could you please post the correct link.
Thank you very much
Lukas Bedajanek
(3,042 Views)
I forgot to put space between link and comma. Link is:
Maciej
(3,033 Views)
