How to take voltage measurements every minute
Accepted by Wolleee
Use Delete from Array.  Leave the Index and Length inputs unwired.
Message 11 of 15
(1,148 Views)
Raven,
THank you for that example, i feel that it is almost complete.  Where do i wire my data from measurement to the ramp? or do i have to index the data to an array and then wire it to the ramp?
-Matt
Message 12 of 15
(1,140 Views)
The ramp is just there to create some sample data. I did that just so I could easily tell it was wired correctly and was spitting out the last element of the array.  It doesn't belong in your application.  Your array of data goes right into Delete from Array.
Message 13 of 15
(1,138 Views)
That works great.  Thank you very much!!
-Matt
Message 14 of 15
(1,133 Views)
Hello:
I am using a NI9234 module but instead humidity i would like to measure temperature.
I make the reading of one of the channels of the module NI9234 that I have connected the thermocouple type T and I have this channel configured in DC coupled. From the host I read the fifo where the data is write and using a thermocouple conversion module I made the conversion of the readed data into a T values. But I think that my configuration is not well done.
Which coupling do you use? Do you made any conversion, what is your configuration for the conversion module?
Message 15 of 15
(937 Views)
