How to turn off the dialog box in the Write to Spreedsheet File
I am saving data in a loop using "Write to Spreedsheet File". When I gave a constant path to this Vi, it was fine. However, when I gave a path defined by a global variable, it consistantly popup dialog box and asked for my choice.
How can I turn off that dialog box?
Thanks.
Smiley Happy
(2,695 Views)
Simply ensure that the path in the global variable is valid.
It could be that you have a race condition and the global is read before a valid value gets written to it from elsewhere. Can you show us some code?
(2,693 Views)
Sounds like the global is uninitialized.  Or like altenbach said, invalid.
Tim Elsey
Certified LabVIEW Architect
(2,671 Views)
