a problem with data acquisitioning in LV 7.1 (transition from Traditional NI-DAQ to NI-DAQmx)
Hi to everyone,
I have a problem with data acquisitioning in LV 7.1.
I made a transition from Tradiotional NI-DAQ to NI-DAQmx in my LabVIEW application.
The problem I have is that when I acquire data in Traditional (without writing somewhere -
just reading) then there is no scan backlog data. But when I acquire data in application that
acquisition is based on DAQmx than a scan backlog indicator shows numbers from 20 to 50 for
about 6 min and then that number quite quickly increases until I get an error (unable to
acquire data. The data was overwritten).
Acquisition settings are the same in both cases. When I acquire with DAQmx I use a global
channels. Is a reason for that phenomenon in global channels data procesing? But it seems
strange why does it flows quite smoothly for about 6 min and then it stucks?
Ero
Message 1 of 14
(3,913 Views)
Hi Ero,
Did you read these links - Getting Started with DAQmx and Transition From Traditional NI-DAQ to DAQmx?
- Partha ( CLD until Oct 2027 🙂 )
Message 2 of 14
(3,913 Views)
Also, pl do read from this post onwards.
Message 3 of 14
(3,913 Views)
Hi parthabe,
Before I made a transition I read this link - Transition From Traditional NI-DAQ to DAQmx.
Now I am going to check out if in Getting Started with DAQmx is something I overlooked.
Thank you for your answer.
Message 4 of 14
(3,905 Views)
Thank you for your response!
Message 5 of 14
(3,898 Views)
If you have an old Daq unit it may not be compatible with DAQMX. Which DAQ unit do you have? I think NI have a list showing which DAQ driver you can use with your card
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 6 of 14
(3,890 Views)
Hello Coq rouge,
I have installed two DAQ cards (NI-PCI 6036E and NI-PCI 6071E) and the latest NI-DAQ 8.9 driver which supports both DAQ cards.
Thanks for you response.
Message 7 of 14
(3,881 Views)
I think you have misunderstood his question.
It is not the question of support for the cards, but whether or not the driver supports both Traditional DAQ devices & the latest DAQmx devices.
Hope this clears the air...
Message 8 of 14
(3,874 Views)
Thanks parthabe!
Yes I misunderstood a question of Coq rouge.
And as you write down the driver supports both Traditional DAQ devices and DAQmx devices.
Thanks again.
Message 9 of 14
(3,864 Views)
Hi to everyone again,
I've found out a new fact about the problem I have.
A page file usage is rising at data acquisitioning in
application based on NI-DAQmx (without writing somewhere -
just reading).
Why does it happen?
Is there any connection with a scan backlog data?
Because a scan backlog indicator shows the amount of data
that depends on a sampling rate.
If I acquire 19 channels with 10000 Hz then a scan backlog
indicator shows a number from 20 to 50.
And if I acquire with 50000 Hz then a scan backlog indicator
shows from 130 to 150.
But the strange thing here is that data flows normally for
about 6 min (a page file is increasing anyway and a scan
backlog indicator is stable - from 20 to 50 or 130 to 150)
in both cases and then after 6 min scan backlog number quite
quickly increases until I get an error.
An amount of a data accumulated in the page file is from 150
- 180 Mb from start to end of acquisition.
And when I acquire with an application that based on
Traditional DAQ then there is no scan backlog data and there
is no change in amount of a page file.
Message 10 of 14
(3,822 Views)
