How to update a 1d array multiple scatter graph/plot
 Hi, i am trying to append data to the single plot graph you see below.  It is a 1d array.  When i build another array to append to this, it becomes a 2d array and am not quite sure how to manipulate this data into another graph/chart.  I have a set x-scale from -10 to -100 and on each iteration, about 100 y values are inserted to say -10 and then -20 (x scale) and so on until -100.  The graph will be of scatter type.
Any suggestions?
Message 1 of 11
(6,273 Views)
You can do "build array" and right click and choose concatanate inputs if you want a continous value graph. Or are you having trouble diaplaying a 2 d array as such?
Message 2 of 11
(6,260 Views)
Hi muks, i am using LabVIEW 8.5.  Have read about setting this and when i checked this - it is enabled and greyed out.  I can build the array but when it becomes a 2D then the graphs & charts just dont want to know.
Message 3 of 11
(6,257 Views)
Sorry but I am not getting this. Can you post a screen shot of your output?
Message 4 of 11
(6,255 Views)
Hi Grant,
the main problem is you don't show us all of your code!
The shift register already contains a 2D array, that's why concatenation mode is enabled for the build array... Change the data in the shift register to 1D array!
Message 5 of 11
(6,251 Views)
Hi, the previously posted jpg is pretty much my current output. The (Array of Pts) Single Plot is a 1D array.  This works fine for one iteration.  ie For 1 x-scale value, i plot 100 y values on say x=-10.
My problem is that i want to loop this in my while loop and add more x values but retain previous results on the graph.  Now i thought that by using a build array would work but because it creates a 2D array, i dont know what is the best method of putting the new data into a graph.  Dont think build array is correct.
Message 6 of 11
(6,250 Views)
Hi, here is the vi.
Message 7 of 11
(6,249 Views)
Accepted by Grant_C
Hi Grant,
as said before: the build array is forced to create a 2D array by your shift register. Change the default constant to an 1D array!
Message 8 of 11
(6,245 Views)
Hi, i have changed the shift register to 1D and all is well.  Why does it automatically create a 2D.  Something so simple causing so much problem.
Message 9 of 11
(6,244 Views)
Hi Grant,
it depends on the order of wiring. When you first set the shift register then all is fine Smiley Wink
Message 10 of 11
(6,239 Views)
