How to use DSC to log timestamps of the pulses?
I am a new user of Labview and have problem when I use DSC in my application.
In my application, I used two analog outputs to generate analog waveforms; two counters to count two pulse trains; a SCXI output to produce required current; RS485 port to coummunicate with other devices using MODBUS; and try to use DSC module to log the timestamps of another digital waveform. All these should work simutaniously. I stucked at the last part because I can get time data.
What I have done with DSC include:
1. Used MAX to set up a virtual channel for a digital input of SCXI 1162HV, passed verifying test in MAX
2. Chose DAQOPC server in server browser, passed the tests in configuration utility
3. created tags using 'configure t
ags' in tools menu.
setting update rate to 0.2s and deadbands to 1%
The problems are:
1. when I tried to connect tags to a real-time trend indicator using HMI wizard, I got an error from wizard and could not connect the tags
2. when I tested the operation using a 50% duty cycle 10Hz pulse trains, the trace view of historical data of tags in MAX showed a waveform with variable pulse width.
I also adjusted the update rate to 0.001s, but still received a strange waveform by trace view.
How can I deal with it? I really appreciate if anyone can help me out of this trouble.
Yours
Steven
(2,882 Views)
What is the error that you got when attempting to use the HMI wizard to connect to the real-time trend?
What version are you using?
Robert
(2,882 Views)
