How to use EncloseSelection2? How to programmatically enclose selected objects with case structure?
I am trying to create a quick drop for enclosing selected block diagram objects with error case structure. I was trying to use Move Selected Objects Method at first without any success (the method was returning error code 1 no natter I tried). Then I found Enclose Selection 2 Method which is exactly what I need (based on the help). But it doesn't work... In the attachment you can find my test VIs.
Can anyone help me with this?
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(3,538 Views)
Accepted by bienieck
Ok, so the problem was that when a new object is created, the selection list is cleared.
Michał Bieńkowski
CLA, CTA, CPI
(3,495 Views)
Can you elaborate on how you worked around that?
Michael
(3,166 Views)
If you get the selection list before creating the object, you should be able to use that same array to set the selection list. Basically you're selecting the same items after it gets unselected.
(3,154 Views)
FYI there's a right-click plugin for wrapping selected diagram code with an error case:
https://forums.ni.com/t5/LabVIEW-Shortcut-Menu-Plug-Ins/Wrap-in-Error-Structure-llb/ta-p/3524283
(3,149 Views)
