How to use GetPropertyValue.vi for a 2D-array?
i have a 2D array in TestStand that i want to read in labview using the SequenceContext and the GetPropertyValue.vi.
It seems as i can only read 1D arrays with this vi.
Is there a solution to also read 2D arrays?
Thanks for help
Message 1 of 9
(4,951 Views)
The GetPropertyValue.vi provides the block diagram.
I never tried it, but you could copy the Numeric Array version to your project and modify it to have a 2d array.
Two things to take care/consider:
1. As said, i never tried it. It is possible that 2d-arrays will not work for this transfer.
2. DISCONNECT THE MODIFIED 2D-VERSION FROM THE OTHER (POLYMORPHIC) API FUNCTIONS. Never alter the defaul TS API! Treat this VI as a complete stand-alone one.
Norbert
Norbert
Expert: Geometry
Message 2 of 9
(4,939 Views)
Solution 1. You can Create a variable with 2D array and Map this variable to Input Node of LabVIEW Vi where you need this 2D Array Value. Make sure you are passing the Values to 2D array before the sequence step calling LabVIEW Vi.
Solution 2: Basically the Get Property will access the Variable by its Name and using Invoke Node, a Reference datatype value will be passed to Variant to convert to expected type. So Changing the Reference datatype in get  property vi fro, 1 D to 2D Array will solve your problem (Not yet tried in Real time but hoping that it needs to work)
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 3 of 9
(4,931 Views)
Solution 2 is working. (and saved under a complete new separate filename)
Message 4 of 9
(4,924 Views)
What about the other way "SetPropertyObject.vi"?
Here it seems not so eays as in the Get vi.
Message 5 of 9
(4,917 Views)
No, setting a multi-dimensional array is not so simple with TS API.
Before digging more into this:
The recommended way to exchange data with a module is to pass it directly by parameter rather than using the TS API in the module. Is there a specific reason why you are not using parameters?
Norbert
Norbert
Expert: Geometry
Message 6 of 9
(4,906 Views)
I have about 20 parameters that i want to read and set. It is easier if there is only one sequencecontext parameter.
But then i will pass the 2D array separate in and out.
Message 7 of 9
(4,901 Views)
Whats your Exact requirement on SetPropertyObject.vi?
As SetValVariant Function accepts variant as input it will take Multidimension array input so ypu can use the same for Set Function also.
Please provide your exact Requirement....
Kind Regards
Message 8 of 9
(4,889 Views)
I have a 2D array in TestStand.
Now i want to read this array from labview via SequenceContext and display it in a window.
After viewing and modifying and want ti write it back to the StationGlobals and overwrite the existing data there.
Message 9 of 9
(4,880 Views)
