mux function in labview?
We are working with a LabVIEW VI, and we were wondering if there are any buttons or sub VI's that have multiplexer functionality.  We want to put 4 buttons in our front panel, and when one is pressed, we want to choose the set of actions associated with only that button press.  Any help is appreciated.  Thanks.
Ray
Message 1 of 10
(21,244 Views)
One really easy way is in the attached picture.  You could create a subvi with your four inputs and a control line and do it that way as well, but this is probably the most simple.
Message Edited by Will.D on 11-30-2006 03:32 PM
Message 2 of 10
(21,238 Views)
An event structure can be used also. With a separate event case for each button the mux function is handled directly.
Lynn
Message 3 of 10
(21,231 Views)
Lets not forget about the radio buttons.
They are nice because they handle the mutual exclusivity and are a enum just waiting to be wired to to a case structure.
Ben
BTW: they can be customized to look like any type of boolean you want.
Message Edited by Ben on 11-30-2006 03:00 PM
Message 4 of 10
(21,228 Views)
I have tried to implement your functionality for a multiplexer, and it does not seem to be detecting button presses for any other button other than the 'Pressure off' one (default case).  Do these buttons need a particular type of behavior?  Any help is appreciated.  I have attached a screenshot as well as the VI.
Message 5 of 10
(21,202 Views)
It failing for a few reasons.  The easiest thing to do is create an indicator or probe after the "Boolean Array to Number" function.  You will see that you get values of 0, 2, 4 for each button.  If multiples are pressed you get 3, 5, 6, 7.  So your best bet may be one of the other solutions.
Message 6 of 10
(21,190 Views)
i am really really new to labview how can i implement the function you have shown in the pic
Message 7 of 10
(19,781 Views)
Hi zeeshan,
you should just recreate those block diagrams...
I suggest to go through basic LabVIEW courses offered by NI (here, there are other sources too). The pictures above use just basic functions...
Message 8 of 10
(19,762 Views)
can we use multiplexer automatically in labview?
Message 9 of 10
(17,651 Views)
This is a rather old post.  And your question isn't very clear as to what you are looking for.
Please post a new message in the forums and clearly state what you are looking for.
Message 10 of 10
(17,633 Views)
