How to use Labview to collect continuous data from NI PCI 6251 and save data in a file?
I just installed a NI PCI 6251 card and Labview. How to use Labview to collect continuous data from NI PCI 6251 and save data in a file? How can I start? Is there any example code I can use?
Thanks a lot.
(3,698 Views)
Browse the NI example finder, you'll get any info you'll need (Help=>Example finder)
Rodéric L
Certified LabVIEW Architect
(3,695 Views)
You mean in Labview help? How can I install the code in Labview? Can I directly open a vi. document? Thank you.
(3,692 Views)
You've got a much bigger problem than just logging data if you don't have a clue as to how to open a VI. Start with the LabVIEW 101 tutorial before you do anything else (including posting a question). You don't even know how to follow directions. Help>Find Examples is considerably different than the LabVIEW help.
(3,689 Views)
please check NI PCI-6251
You will find examples, tutorials, etc. related to PCI 6251.
Yupeng J.
(3,669 Views)
