How to use Labview to show video live to another remote laptop
Hi, I am using labview with a DAQ device with data reading and a web camera. Firstly I would like to show the reading of DAQ device data and live video on the PC with labview. Secondly, I would like to access both device data and video on a remote laptop preferly on a web browser.
Could anyone guide me in how to this could be done. Thanks in advance.
(3,043 Views)
A good idea is to do a quick search of the forums and NI's site. There's tons of stuff about regarding remote front panels, here's NI's tutorial for setting them up :
http://zone.ni.com/devzone/cda/tut/p/id/4791
Have a go at this and then come back to us when/if you have any specific questions
Good luck,
-CC
p.s. Blast! Pressed the "Me Too" button by mistake!
"If anyone needs me, I'll be in the Angry Dome!"
(3,035 Views)
I had the same issue.
A very easy method of resolution is the DataSocket.
Communicating Two VIs in Two Computers Using DataSocket:
https://decibel.ni.com/content/docs/DOC-4905
Sending an Image over Data Socket:
http://zone.ni.com/devzone/cda/epd/p/id/2307
Hope this examples will help you.
_____________________________________________________________________
---Please mark a post as a Solution if it solved your problem ---
(3,029 Views)
Is there any way to use a web browser to access to the video without any labview on the client or remote PC such as mobile phone browser?
(2,986 Views)
I have tried using the web server and was able to view the vi in local host. However, I am not able to view the vi using web browser through another laptop. I had using the ip address through ipconfig in the format of http://"my ip address":8000/My%20vi%20file.html but to no avail. I have also disable my firewall on the server side.
Any help is appreciated. Thanks.
(2,982 Views)
edit: replied to wrong post
(2,974 Views)
