labview tektronix data retrieval
I am using LabVIEW 2011 to configure and control data capture on a Tektronix MSO2014 oscilloscope. This all works fine and I can see the trace on the scope display. Now I would like to retrieve the data on the display into LabVIEW so that I can save it on the WIndows 7 computer in a file. Failing that, a second best option would be to configure the scope to create a fiel with a meaningful name and save it onto a USB drive inserted into the USB port on the front of the scope.
I have had no luck in finding a way to do this in LabVIEW so far. Any help would be appreciated.
(2,648 Views)
Have you checked the example programs?
Go to Help >> Fine Examples
Search for MSO2014 (or just 2014)
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(2,644 Views)
http://www.ni.com/academic/students/learnlabview/
start with LabVIEW 101
(2,638 Views)
