How to use MGI's Read Write Anywhere
I have an NI cDAQ and am writing a VI to configure it and acquire data.  I have a number of controls (numeric, string and boolean, also clusters of arrays of controls) and would like to be able to save their values to a configuration file.
I have installed the MGI Read-Write Anywhere VIs and am just experimenting to find out how to use them.  Is there some kind of user guide for them?  I seem to be able to write a file (save_cfg.vi, .jpg).  Trying a value of 521.3, for instance, the written file looks like this:
[My section 1]
MGI RWA Section Options=2.0.1 %04Y%02m%02d %02H%02M%S%25u*~|.%d*~|.,*~|.%#_13g
Value=521.3
When I try to read the file, my code read_cfg.vi finds "My section 1" but there is then an "Error 91 at Variant to Data" with possible reasons: "The data type of the variant is not compatible with the data type wired to the input".
I have tried a variety of different data types for the "type" input of variant to data without success.  I suspect it is just a matter of having the correct format strings...
Can anyone help?  Thanks
Roger
(3,140 Views)
You are writing and reading different datatypes. Try this
(3,130 Views)
As gregoryj replied.
In your case in your read you have the wrong type, and I believe you wire your format to the type. See below:
mcduff
(3,117 Views)
