PXIe-6592 SFP
I am using NI PXIe-6592. I tried to run the example project "NI PXIe-6592R Aurora Simple Streaming", but failed. The program is suspended at the write port.vi.
I connected SFP transceiver to port 0 and port 2 instead of SFP+ transceiver. Can I use SFP transceiver in PXIe-6592?
Thanks.
(2,750 Views)
Hi!
I actually don't have a certain answer, but you're posting this problem in the LabVIEW forum, I recommended you to post it in the PXIe forum, there are more people specialist in those topics.
(2,724 Views)
I would not expect that to work, as SFP transceivers are operational up to 3.125 Gbps and the example you're trying to run is 10.3125 Gbps.
(2,718 Views)
