How to use Nokia PC Connectivity API in labview?
I wish I could use the camera on my Nokia phone in my labview project, in this case the AT command doesn’t apply. I guess Nokia_PC_Connectivity_API_3.2  (consist of LIB files and  header files)  might be useful, but I don’t know how to load a static library in Labview.  Do I have to write a C program first before labview could use those API function? Or is there a simple way to control my nokia phone?
Would be grateful if anyone could help!
Message 1 of 9
(5,300 Views)
Hi larryD,
if you have a dll, then you can call the exported functions with the "Call Library Function Node". No need to write a C program.
Mike
Message 2 of 9
(5,299 Views)
Thanks Mike, I'm going to try ur suggestion.
Message 3 of 9
(5,294 Views)
Did you find the solutions how to use static library? I have the same issue, here.
If so, please share with me. (thomaschae@paran.com)
Thomas-
Message 4 of 9
(4,686 Views)
 You can use the Tools>>Import>>Shared Library(.dll) in LV to create VIs for your DLL for convenience.
Message 5 of 9
(4,639 Views)
Message 6 of 9
(4,639 Views)
It supports DLL(*.dll) only, not LIB(*.lib). I need LIB interface.
Possible options are,
1) to make a new DLL calling LIB by using C/C++ complier (ex. visual c), then use "Call Library Function Node",
2) to generate new c source code calling external LIB, then using CIN(Code Interface Node).
They looked available, but  NI has addressed that either one won't work, unless original code desinger makes a new clean dll.
Do you have another idea?
Message Edited by thomaschae on 03-04-2010 10:00 PM
Message 7 of 9
(4,629 Views)
Don't go the CIN route! They are legacy technology and not supported anymore on all LabVIEW platforms. The shared library (Call Library Node) interface is the way to go nowadays.
And I don't understand your second last sentence. A lib while having the same file ending is not a standard format as its internal layout and format depends highly on the compiler that was used. So there is no way NI could make a general purpose interface node to interface directly to lib files. It is even so bad that a lib created with one comiler can not usually be used with a different compiler.
Message Edited by rolfk on 03-05-2010 07:44 AM
Rolf Kalbermatter  My Blog
Message 8 of 9
(4,618 Views)
Yes, my point was that we don't seem to have any way to use library(*.lib) file.
I requested the original library maker to develop DLL file available to LV environment and the result seems now promissing.
Thanks, all.
Thomas-
Message 9 of 9
(4,610 Views)
