How to use PID function to control a DC motor? ?
Hi everyone,
I wanna control a 6v DC motor using PID control toolkit 8.2.
- a close loop control system with an encoder sensor
- using a DAQ card model: NI USB-6008
- the DAQ card will be able to output pwm signal to the transistor then to my motor
Im stuck at getting pwm signal from the pid.vi and i wanted to know what is the process variable (PV)
pls help me on my problem, if can pls make an example VI for me
Thanks !
(2,490 Views)
(2,476 Views)
