How to use SENT API?
i just downloaded the SENT API from NI homepage and installed it via the JKI VI Package Manager .
(https://www.ni.com/en/support/downloads/tools-network/download.sent-driver-api.html)
But i dont find the "new" installed SENT feature in my LabView2010.
So where can i find the new SENT features after the installation of the SENT API?
And is there any tutorial how to use that things?
Thanks a lot.
Greetings,
Ben
(4,425 Views)
Hello Ben,
I've not used this tool myself, but it appears to be FPGA-specific.  Have you attempted to access the API from an FPGA VI (a VI created under an FPGA target in a LabVIEW project) rather than a standard labview VI?
Tom L.
(4,402 Views)
Hello Ben!
You can find examples in the folder
C:\Program Files (x86)\National Instruments\LabVIEW 2013\examples\IEDriver\SENT
The SENT API is available only in FPGA VIs under Connectivity > SENT
  Georg
(4,377 Views)
Hy,
ok i found it.
It works.
Thanks a lot for your great support.
(4,358 Views)
Hey I am using this API for the first time and I have some doubts, in the API details it is mentioned that this can be used to create a SENT receiver using NI 9401, 9402 & 9403 with crio. Can it also be used to create a transmitter? if yes, is there any example on this?
(1,431 Views)
