How to use a Third Party DAQ evaluation board/ module
Hi abikutn,
You can search for NI products that meet your needs by searching here. You can narrow down the search based on your constraints.
Rohama K.
Message 11 of 17
(1,003 Views)
Yayyy !!! ... Smiley Happy
        Finally ANALOG DEVICES have agreed to give me the required drivers for labview to control their evaluation board named HSC EVALC
http://www.analog.com/static/imported-files/eval_boards/265181843HSC_ADC_EVALC.pdf
Now I have to communicate my labview with this EVAL board which is basically a FIFO board.
Please guide me how to start. I can pick up the rest when I get the knack of it eventually.Also I have attached with this message a JPEG to illustrate what I am exacttly upto. Advices please.
Thank you guys
Abhilash S Nair
Research Assistant @ Photonic Devices and Systems lab
[ LabView professional Development System - Version 11.0 - 32-bit ]
LabView Gear:
1. NI PXI-7951R & NI 5761
2. The Imaging Source USB 3.0 monochrome camera with trigger : DMK 23UM021
OPERATING SYSTEM - [ MS windows 7 Home Premium 64-bit SP-1 ]
CPU - [Intel Core i7-2600 CPU @ 3.40Ghz ]
MEMORY - [ 16.0 GB RAM ]
GPU - [ NVIDIA GeForce GT 530 ]
Message 12 of 17
(986 Views)
Pretty picture but not worth anything in getting your question answered. Since you seem to be the only one with this driver and you have provided 0 details on it, how do expect anyone to answer?
Message 13 of 17
(979 Views)
Thanks for the immediate reply.
But I am a newbie ... What details exactly are you expecting for ? ... I mean the drivers they provided me has the following attached files.
I think there is somehow a way to control this board with labview using these files. Escpecially when they have given the Direct VI .
Please find the attached files and help me know better.
Thank you.
Abhilash S Nair
LabView Gear:
Message 14 of 17
(976 Views)
Hi also this file was sent to me.
Abhilash S Nair
LabView Gear:
Message 15 of 17
(974 Views)
Attaching the files is the sort of detail you could have provided.
With just a brief look, the VIs are interfacing to a couple of DLLs (adidatafunc.dll and FIFOInterface.dll). The installer in your second attachment will probably install one or both but I cannot run it.
Other than that, none of the VIs appear to have any documentation and I don't see anything that tells someone where to start. Try experimenting. Doubt you could do much damage. Smiley Wink
Message 16 of 17
(968 Views)
Smiley Happy
yeah thanks! ... They havent provided me with any documentation either. However I will start experimenting.
Is there any steps or methods of how I have to go about using these files to communicate to the hardware ?
I mean any tutorials from NI.
I shall start experimenting right away. Just need the start.
Thank you
Abhilash S Nair
LabView Gear:
Message 17 of 17
(960 Views)
