How to use a slider to turn on and off lights
Hi guys. i am fairly familiar with Labview now but cant seen to get my head around this problem. i have a slider which is numbered from 1 to 10. below the slider i inserted 10 LED lights. my aim sis to use the slider to turn on and off the lights. for an exmaple, when i set the slider to one, the light on the far left should go on. when i set the slider to 2, the first light should go on and the second light next to it should go on, and the pattern continues. i thought of using the number to array boolean but it didnt seem to do the trick. could you please help me out. i have attached the basic layout of how i wanted the objects to be arranged
kind regards
joe
Message 1 of 11
(4,298 Views)
Accepted by topic author Jus Joe
Maybe something like this?
Message 2 of 11
(4,282 Views)
Genius! totally what i was looking for. thats a lot
Message 3 of 11
(4,277 Views)
Ok i followed your example and is definatley a step foward. for the bast hr and a half i have battling to figure out why i cant get the program to work with negative numbers. i have resized the slides scale to -1 and 1 with 0 inbetween. -1 should turn on the red light on the left, 1 should turn on the green light on the left and 0 is neutral, all lights are off. i have got the 0 and 1 working as expected but cant get the -1 to respond :s. any tips again please?
Message 4 of 11
(4,263 Views)
Ok i think i have done it the right way :D. let me know what you think
Message 5 of 11
(4,259 Views)
Overly complicated.
Message 6 of 11
(4,250 Views)
If you still want multiple LEDs on each side, here's one possibility... (For only two LEDs, use Dennis's solution.)
Message 7 of 11
(4,241 Views)
wow! simplicity at its best! thats really straight forward to understand. i think you are right about making complicated circuits. the reason why i had asked to know how to do this was because i wanted to learn how to control motor directions using a slider. so after i thought i had got the easiest way of giving out 2 different outputs using a slider, i replaced the lights with switches that changed the direction of the motor. i successfully did this for the first motor and it rotated fairly well, but wanted to control 4 in total. so i simply copied and pasted the code and re-asigned the switches to different motors. when i did this, the results did work BUT the motors went very very slow. the movement was not steady and kept skipping. i think this its due to the coding being overly complicated thefore causing a serious lag. if you could please have a look
kind regards
joe
Message 8 of 11
(4,201 Views)
Why do you coninue to post if you do not take the given advice? Why should anyone answer when the advice is ignored?
Message 9 of 11
(4,197 Views)
i apologise. i didnt mean to seem like i was ignoring feedback. i just wanted to show what i had done so far. im working on the code now as we speak using the picture provided from the previous post.
kind regards
Message 10 of 11
(4,194 Views)
