Need help in TCP/IP expert
as the attachment , the blinkblink.vi is the main function i want to do .
how do i connect using the TCP/IP ?using the testserver.vi and the testclient.vi
need help. any expert here?
(2,686 Views)
no people knows how to do it ?
(2,667 Views)
Be patient.  It's Sunday, there are fewer people on the forums.
Have you looked at the TCP/IP client and server examples in the Example Finder?
(2,663 Views)
define "do"!
Do you want to send the new LED state whenever the two booleans change? What is the server supposed to do with the data?
(Your blinker code makes little sense, for example [i] is always less than 3 so at least one operation is meaningless. Also, the VI consumes all CPU resources when the switch is off. It is often easier if you make a clean diagram layout, not with wires going in all directions or often nowhere. Have you done any tutorials or classes?)
(2,650 Views)
