How to use hpvee driver in Labview
Hi;
I am having trouble with some kind of old oven. I have to control this oven by Lab view (serial communication)
I have a driver file which is written for Hp-vee.
So my question is; whitout reinventing the wheel How can I use this oven driver (designed to use with hp-vee) in labview;
If you have any suggestions It will really help me.
By the way whi wonders about the oven, it is a 1989 VMT 07/35 test chamber
kind regards
m. Bolatkale
(4,230 Views)
What kind of driver file is this?  Need more info!
(4,223 Views)
I am not sure about using the Vee driver but if it is a serial device and you have the command set, writing a visa driver (especially for a simple device like an over) is usually not too hard.  essentially all you have to do is open a visa session, send the parsed command string, wait for the reply parse the ascii reply and when done close the visa session.
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(4,217 Views)
the driver that I was talking about is an INSTRUMENT DRIVER FOR HP-VEE (Agilent VEE).
the problem is that I do not know the exact commands for the oven threfore I am hoping to use this
driver.
In any case I attached the driver. The other problem is that the comments are written in dutch:)
kind regards
mubo
(4,211 Views)
Hello Mubo,
I did a search on google on the serach word VMT0735. With this I found out that the manufacturer of this oven is: Heraeus and the type is: VMT 07/35. I did a search on our Instruemnt Driver Network http://ni.com/idnet but there was no Instrument Driver available for this oven.
I did a quick search and found the website of this manufacturer: http://www.kendro.com/heraeus.html
Contasct them to maybe get the command set for this oven so you can use the VISA functions to program it.
Hope this helps,
RikP
Rik Prins, CLA, CLED
Software Development Engineer
(4,182 Views)
If you have not used Labview and VISA to write a driver dont be intimidated, I wrote my first a few years back with this method and it was not a steep learning curve took about a day to figure it out.  This is a simple way to go, especially  if you only are only interested in a few commands (I.E.: set temp, get temp, set alarm .... like most ovens have).
Paul
Paul Falkenstein
(4,180 Views)
