MAX 7041/6040 export
I got 2 PC with PCI 7041/6040E RT Target. I'd like to export tasks and channels of the 6040 with max from one PC and import it to the other.
But when i chose RT::1 (which is my 7041 RT device) in the export wizard, it doesn't show me channels and task for the 6040 on the 7041 target, it only show me the 6040 itself (for nce file, nothing for ini file) under RT::1, and others channels under System (which are linked to a 6534 DIO device).
I've got Labview and Labview RT 8.0.1 and DAQmx 8.1.
Does anyone have an idea on how to export this ?
(3,085 Views)
Hello Ludos,
Could you please be more explicit ?
I don't clearily understand what you are waiting for...
As far as I understand:
1/ you have two systems, each one have a 7041/6040 RT card.
2/ you want to copy your config (including tasks and channels) from your first system to the second one.
3/ When you copy your config on the second one, you don't see your previous tasks nor channels...
That's the idea, isn't it?
BRAUD Jean-Philippe
Field Sales Engineer - Nord et Centre France
LabVIEW Certified Developper
(3,056 Views)
Yes,
In fact, the problem is in step 3 : I can't export channels and tasks because thy are not listed in the export wizard.
The solution I found is to embed the channels in my Labview project. But I think there's a problem with MAX and/or 7041 cards and/or daq-mx 8.1.
Thanks for interesting in my problem
Ludos
(3,052 Views)
