How to use labview for operating a controller board with sensors,drivers etc?
Application/Requirement:
I have an auxiliary controller board which is connected to several sensors, drivers & solenoids. This controller board is connected to PC via an USB to CAN adapter. The adapter has a CAN 2.0 interface with the board & USB 2.0 interface with PC. The controller board is operated via GUI screen by LabVIEW.
Queris:
Is there any example code for the above mentioned application?
Do i need any add on modules for this application?
Sithu
(3,157 Views)
How can you control a sensor with labview via USB interface?
(3,130 Views)
Try to explain in more details what you are trying to do.
Witch sensors are you taking about ?
What kind of board is it ?
(3,119 Views)
Well the explenation is better described in this double post here
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
(3,109 Views)
