Memory or data structure corrupt
I have a .NET application in which in try to determine the VI contained in a llb file. This is the code:
LabVIEW.Application lv = new LabVIEW.ApplicationClass();
LabVIEW.Library lib = lv.OpenLibrary(@"C:\Program Files\National Instruments\LabVIEW 8.5\examples\general\strings.llb");
I'm getting the error: LabVIEW: Memory or data structure corrupt.
I know the LabVIEW.Application reference is correct because loading and running normal VIs works fine.
What could be the problem?
Message 1 of 9
(7,237 Views)
Hi there
LV documentation of "OpenLibrary" states:
"Opens the LabVIEW project library"
I don't think you need an object for llbs, because they are treated as directories.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Message 2 of 9
(7,231 Views)
I agree that from within Labview llbs are considered directories, but I want to determine from within my .NET applicaiton what VIs are inside an llb file. How can I do that?
Message 3 of 9
(7,227 Views)
Hmm, in case the llb is part of a project then open the project with OpenLibrary and then use the ProjectItem.Children Property to get a list of all sub items (= VIs in this case).
Best regards
chris
Message 4 of 9
(7,224 Views)
When I use OpenLibrary to open the llb file, I get the 'LabVIEW: Memory or data structure corrupt' error.
The llb file is not corrupt because I can open it in LabVIEW. I have this error message with every llb file.
Message 5 of 9
(7,218 Views)
Like already mentioned before: The purpose of OpenLibrary is to open a project, NOT LLBs! And because every LLB is NOT a project, you get the error with each LLB.
Best regards
chris
Message 6 of 9
(7,214 Views)
OK, now I see...
OpenLibrary is for lvlib files.
OpenProject is for lvproj files.
So there is no way to open a llb file using the COM interface?
Message 7 of 9
(7,212 Views)
Accepted by topic author sven9
"So there is no way to open a llb file using the COM interface?"
See my post from 06-24-2009 03:29 AM.
Or create a LV dll that calls "List directory" and returns the list of VIs. Bind that dll tou your app.
Best regards
chris
Message 8 of 9
(7,209 Views)
I have a similar problem trying to open a project from a .NET application. The codes look like below:
LabVIEW.ApplicationClass lv = new LabVIEW.ApplicationClass();
LabVIEW.Project m_proj = lv.OpenProject("C:\\Projects\\LV_Example\\lv_project1.lvproj");
I am getting the error:  LabVIEW: Memory or data structure corrupt. I face to the same error trying to open a library (.lvlib) using openLibrary() function. What can be the reason?
Cheers,
Pari sa
Message 9 of 9
(6,955 Views)
