Showing results forĀ
Search instead forĀ
Did you mean:Ā
How to use more than two condition in if statement inside the formula node?
I know how to use the if and if else in the formula node, but is there any way that I can check multiple cases inside if statement?
for instance: How to write the following syntax in the formula node?
if (u1==1) && (u2==1) && (u3==1) && (u4==1)
Ameer
(4,770 Views)
Rather than futzing with the formula node, I would just use the native LabVIEW functions.
Bill
CLD
(Mid-Level minion.)
(4,729 Views)
Bill, do you mean by native LabVIEW functions the block diagram provided by LabVIEW?
Do you think this will create a bulky system?
Ameer
(4,726 Views)
"Bulky"?  Formula nodes get bulky.  But the main reason I would use the native LabVIEW math functions is because I don't have to check for typos.  šŸ˜‰
Bill
CLD
(Mid-Level minion.)
(4,722 Views)
Accepted by topic author janabiam
Hi Ameer,
it gets very clean once you employ the polymorphism in LabVIEW:
Use arrays to handle the same operation on multiple elements…
Edit: those "u" variables probably contain boolean values, so you should also use a boolean array in LabVIEW. This way you don't even need this comparison…
(4,719 Views)
Thank you for the help.
Ameer
(4,478 Views)
