How to use one single boolean button to control a multiple while loops?
I've posted the attached file and you will see that it doesn't let me use local variable for stop button, but I need to stop all the action whenever I want but more than one single button on the front panel would look ugly... The file represents the Numeric Mode of
HP 5371A. thanks for your time
(2,921 Views)
In order to use a local variable, you can change the mechanical action of stop button (Switch When Pressed will work), or create a property node for it and select values. You'll also have to do a lot of work changing those for loops into while loops so that you can abort them.
(2,921 Views)
