How to use/port LabVIEW 32-bit Instrument drivers in LabVIEW 64-bit
Hello NI Community,
I am working with a device from Rodhe SGS100A. They have 32-bit LabVIEW instrument drivers and my project is in LabVIEW 64-bit.
Is there anyway I can use those VI's in my project? They don't show up under instrument drivers (which is kind of understandable).
So my question is: 1) Is it possible to use them in 64bit?
                              2)If so then how?
Any help on this would be appreciated.
Message 1 of 12
(5,288 Views)
Hi sridatta04,
I have just downloaded the driver myself and it is run off a 32-bit dll which would have to be recompiled for use in 64-bit environments. So, unless someone else can find something I do not think it is going to be possible with what R&S have provided.
However, it could be worth a quick comment to R&S to ask if they will recompile for you.
Message 2 of 12
(5,279 Views)
Using LabVIEW 32bit would seem like the obvious solution.
Is there any specific reason that your project would not work in LabVIEW 32bit?
Message 3 of 12
(5,263 Views)
The end customer would like it in 64-bit labVIEW. There will be further development on it from our and customer's end and this is the only odd man out with 32-bit drivers.
Message 4 of 12
(5,260 Views)
I'm always weary when people say 'I want 64-bit'... It can cause a lot of issues like this.
As a software developer I always try to use LV 32-bit when I can.
I am currently writing a large application where I need the added memory depth - so there are definitely use cases... but keep asking why.
The response I normally get when I ask why is 'Because I'm using a 64-bit OS'... This is not the correct answer.
Message 5 of 12
(5,258 Views)
They need to provide more specific reasons than that. As a software provider, you need to advise them about reasonable choices.
Message 6 of 12
(5,250 Views)
Totally agree to your point.
Message 7 of 12
(5,247 Views)
Are you sure there are no 64 bit versions?
Below is a quote from LabVIEW driver history for the R&S® SGS100A SGMA Family RF Source
2.2 Installation
Install the 32-bit driver or 64-bit driver based on your LabVIEW type, not based on your Windows OS type.
In order to use the LabVIEW instrument driver after installing, please copy the folder:
32-bit driver:
C:\Program Files (x86)\IVI Foundation\VISA\GWinNT\rssgs
64-bit driver:
C:\Program Files\IVI Foundation\VISA\GWin64\ rssgs
into your LabVIEW folder:
32-bit LabVIEW:
C:\Program Files\National Instruments (x86)\LabVIEW 2010\instr.lib
64-bit LabVIEW:
C:\Program Files\National Instruments\LabVIEW 2010\instr.lib
After restarting your LabVIEW development environment the driver will then be directly accessible from the Instrument Driver function palette menu:
mcduff
Message 8 of 12
(5,229 Views)
2.2 Installation
32-bit driver:
64-bit driver:
32-bit LabVIEW:
64-bit LabVIEW:
mcduff
Yes there are no 64-bit LabVIEW one's. I came across this document a while back!. Thank you for sharing it though 😞
Message 9 of 12
(5,214 Views)
Are you controlling it with a PCIe card or via the ethernet cable? If the latter, regular old VISA should work.
mcduff
Message 10 of 12
(5,205 Views)
