How to use the activeX file (.OCX) for plot in LV
I am totally to activeX, thanks.
(3,803 Views)
What do you mean by "plot" Do you want to insert a graph object?
(3,799 Views)
Accepted by alex.
If you are new to ActiveX , then I would start here: What Are ActiveX and ActiveX Automation?
Your specifc ActiveX control will have its own documentation on how to program it, so you won't find this information in LabVIEW.
Just out of curiosity, what are you trying to plot and what ActiveX control are you trying to use? Have you tried the LabVIEW plots?
(3,782 Views)
When I load it, I can post a screenshot for it.
(3,771 Views)
The final looking should like the attached screenshot.
It can display point to point data accumulately with colors indicating the point density.
I tried to register the .ocx file succussfully, bu when I tried to insert it into the activeX container, still cannot find it in the drill down list.
Any suggestion? Thanks.
(3,741 Views)
This tells us absolutely nothing because you still haven't explained what ActiveX control you are trying to use. There are like zillions of ActiveX controls. What is that a picture of? What application is that from?
(3,726 Views)
