How to use the discrete unit delay function with the simulate signal as the input?
Hi there,
I want to use the simulate signal as the input. First, i downsample the input with the downsampler.vi. Then I want to feed the output of the downsampled signal to the discrete unit delay block and display the delayed signal on the graph.
Somehow I can't use the delay block properly, do anyone know how to fix that?T_T
thanks!!!!
Ivy
please see the attachment
(2,838 Views)
Hi nozombie,
In your VI the Delay VI only delays the measurment for one interation of your simulation loop.  What are the results that you hope to see?
Mike Altmann
Product R&D
NI
(2,812 Views)
