ex stream to disk analog trigger
Dear NI engineering,
i'm using the example program called "Stream to disk" with a PCI 5112. I was wondering, can i use an analog trigger in place of the software one (like i have done in the vi i have attached here).
This is because i'm trying to synchronize a PCI 5412 and PCI 5112 (by using two different vi).
Moreover i saw also the example from your website called "3784.vi" (i have attached it here), but when i start it, it does not do anything. How come?
Thanks a lot for your help,
kind regards,
Gianna
(2,413 Views)
Hi ,
I think that this forum is the same as the  SR 7354392 in the mailbox of National Instrument. So I think that I can close this forum and you can follow me in that SR.
Hossein
(2,381 Views)
