How to use token for instruments sharing?
I am working on the parallel test architecture, now faced a question that how to share instruments among multiple devices under test (DUT for short)?
Suppose we need 2 instruments for the functional test, and 8 DUTs will test in parallel. If instrument 'A' is occupied by DUT #6, so it will be LOCKED until DUT #6 release the token after test complete. Then the instrument 'B' is occupied by DUT #2. Other 6 DUTs will waiting in the queue one by one, and they only can using the two instruments in turns after DUT #6 & #2 release them.
Is there any reference code? Any suggestion is highly appreciated!
"I think therefore I am"
(3,948 Views)
TestStand is perfect for this. All of the functions for this are built-in. I once looked into doing everything in LabVIEW but it just wasn't cost effective. Delivered in a much more timely manner as well.
(3,940 Views)
Thanks for reply.
Of course I know NI teststand, but I am not going to use it. I wanna write my own code. Do you have any suggestion?
(3,935 Views)
Do you want to complete all tests for dut a before moving to dut b or is it test 1 dut 1, test 1 dut 2, etc.? Is there a mux to switch the different instruments to different duts?
(3,927 Views)
All DUTs are test in parallel asynchronously, once a DUT finished all test sequence, it can be removed and put a new DUT for testing.
And, all DUTs can connected to each instruments independently through switch, once a DUT get the token, test program will switch this DUT to the right instrument.
(3,922 Views)
