How to use windows API to open a file browser
I am trying to use the function of GetSaveFileNameA in comdlg32.dll to open a file browser.
But I do not know how to handle the parameters as http://allapi.mentalis.org/apilist/GetOpenFileName.shtml
May you give any suggestion? Thanks.
Message 1 of 8
(4,906 Views)
Hi turbot,
see this link for more information.
Mike
Message 2 of 8
(4,905 Views)
How to define the parameter of OPENFILENAME Structure. Thanks.
Message 3 of 8
(4,899 Views)
Hi turbot,
you can create a cluster with the described data types, set it and connect it to the dll call.
Mike
Message 4 of 8
(4,897 Views)
How to connect the cluster to the dll. There are only a few choice for the type of the dll parameter.
Thanks.
Message 5 of 8
(4,859 Views)
Why can't you use the built-in File Dialog function?
This has been asked numerous times before have you tried a search?
Message 6 of 8
(4,850 Views)
If you'd just search the forum for "GetOpenFileName", you'll find a link to
"Multiple File Selection Dialog".
Modify it (if you need too), and you're done.
Wiebe.
Message 7 of 8
(4,849 Views)
Quite a lot reference, but no exactly ones using comdlg32.dll, any suggestion?
Message 8 of 8
(4,817 Views)
